Zero compression center cylinder.
DavidPaulHarvey
Figuring out my 72 Triumph 65, ZERO compression in the center cylinder, plug looks steam cleaned but top and bottom is looking normal and hitting the numbers I am expecting, I have already ordered my powerhead gasket kit, checked the cylinder with a camera, bore looks fine and the piston isn't rocking either. Could a head gasket blow so bad that I get ZERO compression on the cylinder ?
Take the head off now.-----A blown head gasket can result in ZERO compression.-----But somehow I do not believe you will like what you see with the head off.-----Post some pictures.
DavidPaulHarvey
You hit the nail on the head 🤣 I don't feel deep scoring, just some carbon and what I assume is aluminum smeared to the wall which is flaking off. Debating parting it out now vs pulling the piston, honing the cylinder and slapping a new one in just to see what happens. The mating surface of the head I can get done locally for cheap from a reputable machine shop so I am debating it hard.
I'm a marine composite guy by trade so this engine work is all new to me so I figure it's a good lesson to learn.
No surprise to me.----That will NOT buff out with a cylinder hone.-----Take the engine apart.----Inspect all parts.----Needs 3 new improved pistons in my opinion.----Some will argue but there were issues ( thin piston skirts ) with early 3 cylinder loopers.
