Re: zero compression in #1 cylinder 1981 3.8l
Thanks for the reply, yes I did use sealant on the head bolts before I resembled. I do have a free manual that I found online for the engine and have been reading a lot on the rebuild process but I will admit I did not know I should have rechecked and adjusted the valves. when I took the engine apart I labeled everything so they would go back where they came from So I tore apart the engine again on the side that has no compression in the #1 and decided to try and see if the valves are leaking. Upon visual inspection everything looked fine. So I tried the water method of putting water on each valve and seeing if they leaked. What do you know, the #1 valves leaked. The exhaust valve did not leak any water but the intake valve was leaking fairly well. It took about 15 sec for most of the water to drain out. So I tried again using acetone and it pretty much flowed right out. The other two held water with no issue So It looks like there is my issue. Now I am trying to decide if I should replace the valves as there is some pitting on the valve surfaces but not that bad or if I should get lapping compound and try lapping the valves. Will need to find somewhere that sells the correct valves if I decide to replace them.
Ayuh,.... No matter how bad the valve is leakin', the 1 You say, "Upon visual inspection everything looked fine."
You
wouldn't get a Zer0 compression test....
Unless you hadn't adjusted the valves, 'n the valves were actually Wide Open...
I'm sorry,...
but ya can
Not pull the heads off a motor, 'n put 'em back on, 'n expect the valves to be Properly Adjusted...
If yer gonna play a Mechanic, ya gotta follow
All the rules found in shop manuals...
When ya Don't,.... Well, you can see the results....
No disrespect intended, just tryin' to be Honest.....
Yer spinnin' yer wheels,... bring the heads to a Machine Shop, 'n get 'em rebuilt....
