Re: zero compression on cyl 3 on chrysler 115
okay the plugs...they are odd looking buhw I think, anyhow they are flat on the center electrode, and have no side electrode. i trust that is the right kind for the magnapower ign.
next , the kiddie pool eh...ha....grrrr. seriously though ...it aint no stinking head gasket ...that would be nice...but..a leaky head gasket in all likelyhood would not report a zero compression but rather a lower compression..and its a ZERO...texas size leak!
next the fuel discharge into the bad cylinder...thats what I need to know...what could cause zero compression and no eveidence of fuel...this plug was clean and dry?
and Fucawi and Frank, I got it like this...i am just digging into its issues...I have had it out 5-6 times. so only blame me from here forward....
I could pull the head to just end the guessing...ordered a second fm since the chrysler one is CRAP. where can I web order in a kit for head removal that comes with all the needed o rings and/or gaskets?
i see the lead out labelled tach on the wiring block, but that isnt the pulse I need? Will and automotive inductive tach sensor work off plug lead 1 just for testing?
and lastly the spark test...i have performed these many times on Harleys, but I saw no spark on all 4 of these weird plugs...so is the spark test done the same way...turn it over while the plug is grounded and watch for the arc?
