This priming question seem to crop up every few weeks it seems. And the only right answer is, whatever you want to use is the right primer. Similar to, which is the best 2 cycle oil, or what type paint is the best, or even should I use synthetic or regular oil, or even should I use high octane fuel or not, most anything else in that which is the best realm, everybody has their own opinions and likes. So use which ever quality primer you like for aluminum. And it will be fine.
I go with Zinc Chromate because, the government did their testing on their aircraft for the best longest lasting type primer and they chose Zinc Chromate, I figured I'd go with their testing efforts and use the same. But epoxy primer it good and so is self etching primer. So make your choice and it will work without issues. JMHO
