Zinc relacements
almancuso
I need to replace the trnscom housing Zinc and cube Zinc on the outdrive? Is thisa difficut job? Howsthe best way to do this?
cuzner
Re: Zinc relacements
Its real easy!!! should be a couple of screws, just remove them and, put the new one's on and you are done.<br /><br /><br /> Jim
Ayuh,.......<br /><br />And if we knew What drive you have,........<br /><br />Maybe we'll tell you Where the Screws are Hidden................ :D
phantoms
Thise two are very easy to replace (except for bolt corrosion sometimes). The prop shaft zinc (many people over look) is a little more involved, but not that hard either.
studlymandingo
The small skeg on the AV plate came off of my Mariner two days ago while underway, water pressure pushed the bolt up and out of the lower unit, and I had to buy a new anode, and have to go to a specialty dealer Monday for a new cap bolt.
