nautigator
- Sep 25, 2006
- 4
I have a carbed 140 2 stroke that fires up fine. Within a few seconds, it starts missing and coughs then dies. During the coughing, it puffs fuel/air mixture out from under the #4 carb but I can't see exactly where. I removed the carb plate and looked behind the #4 reed cage. There are no signs the gasket was leaking, or that the reeds are causing the problem. The backside of the #4 carb had tiny scratches or pits in it indicative of something bouncing around between the carb and the reeds. There is no damage to the reeds. I did a compression test and the numbers were fine. The motor was purchased used, and it appears that someone has been through most, if not all of the motor previously. I dropped the #4 bowl off the carb expecting it to be full of trash and found none. I pulled the high speed jet out through the bottom of the carb and it had a small amount of crud right at the top of the threads. Nothing excessive. I am at a loss with what could be the problem. If someone knows, some direction would surely be appreciated.
