Re: need a good range rover forum
How to correctly adjust the power steering box on a Range Rover:<br /><br /> With the wheels in the <br />straight ahead position, turn the steering wheel and measure how far <br />it turns before resistance is felt - any more than 1in calls for <br />adjustment. <br /><br /><br />Raise both front wheels off the ground and <br />support the Land Rover on axle stands, taking safety precautions.... <br />The vehicle front wheel must be off the ground so that you can turn <br />the steering over the full extent of its travel.<br /><br /> Use a 19mm spanner to release the locknut then <br />adjust, using a 6mm Allen key. turn the steering wheel from lock to <br />lock, and then back to the centre. If you can feel any 'tight' spots, <br />the steering is too tight and the Allen key should be backed off until <br />no stiffness can be felt, turning the steering several times over the <br />full extent its travel.<br />Once the correct amount of adjustment has <br />been attained, hold the Allen key in position while you tighten the <br />locknut. This requires some care, as it's easy to turn the Allen key <br />at the same time.
