Re: '79 235hp
Try taking some gas (mixed with oil)and using a spray bottle shoot someinto the carbs,you will need to remove the carb cover ,if the engine starts without a problem,check out your primer and make sure all hoses are connected especially the larger one that feeds it,(you can check it first)when you are priming the systen,can you hear the primer operating,it is possible to hear it operate if you can get close enough,if you cant hear it,you may have a broken connection along the way,you can also turn the red valve on the primer 90 degrees then squeeze the ball or if you have an elec pump,the primer should allow fuel to pass through to prime cylinders.As for the cranking,true if it dont crank fast enough,you will have spark problems. Does the engine souund like it cranks as always?Is the squeeze ball ok,are you sure fuel is being pumped,it might not be pumping fue and be locking up with air,or just not working at all,I think your not getting a prime for starting
