helix54956
- Mar 24, 2007
- 6
I just spent 293.29 in repairs at a local marina. Had the prop shaft seals replaced along with the o-ring and had them put in new water pump kit. Just put the muffs on and ran the motor. after running for about 3 minutes. I have more lower unit fluid leaking out now than i did before I had the work done. I took prop off its not coming from the shaft seal but its coming from way back in there as far as you can see past the bearing carrier nut any info would be great Brian
