Theoutdoorsman
- Mar 6, 2003
- 681
Well, I did the most ignorant thing I could have done Saturday. I ran my fuel cell dry and the motor came to an abrupt halt. When I went to back to prime the bulb, I found it was sucked completely flat. After finally getting the bulb to prime again, the motor is now acting sluggish. Now, it's surging. It acts like it wants to go, but just can't get the rpm's up and hold them there. It drops back a little, say from 5000 down to 4500, and acts like it tries again and again and then again. Rpm's go up and down like a yo-yo. Just to rule out any possible internal problem, I checked the compression to rule out a possible internal problem. They read as follows:
#1- 100 psi
#2- 107 psi
#3- 100 psi
#4- 100 psi
To my relief, this is pretty close to what I had when I first checked compression after the rebuild was completed several months ago. All the plugs looked nice and wet when removed. Would I be right to assume the pick up screen is partially clogged inside the fuel cell? I've never cleaned it in the five or so years I've owned this boat, and it's hard telling WHEN it was last cleaned. I'm assuming this is where I need to start. Any opinions out there? I have an auxiliary tank I can test with, before removing the carbs or turning the first bolt for that matter. Having never removed the pick-up, I could sure use some advice on getting this thing out to clean it. I'd like to remove the tank, but I'd say the whole top cap would have to be removed to do it. Is it possible to clean the fuel cell without removing it? Ahhhh, where to start? Thanks in advance for any and all advice!!! ............ Alan
#1- 100 psi
#2- 107 psi
#3- 100 psi
#4- 100 psi
