Theoutdoorsman
- Mar 6, 2003
- 681
Re: Need some advice guys. I got a good scare Saturday.
It has never really stayed firm. It will firm up for a bit, but once running, it will get soft pretty quick. However, I seldom have to re-prime the system. This is the one thing that I never did, was to rebuild the fuel pump, although I do have the kit on hand. Do you suppose I should remove, clean, and replace the fuel pump prior to trying the auxillary tank. There is no mention as to how to do this in the service manual. Any help would be greatly appreciated. One other note, the fuel pump has no screen (fuel filter). This is why I added the in-line filter. I have some pieces of stainless steel screen material which I could cut to make a screen, if this is possible. I just don't know if one could fabricate one, having never dealt with rebuilding a pump. Anyone have any idea if I could do this? Thanks again............ ALAN
I'm wondering if maybe that much vacuum in your fuel pump tore up the membrane inside and now you've got a fuel leak in through the pulse orifice. It would explain why it's hard to prime too. Do you ever get a nice firm bulb when you prime or does it go soft pretty quickly?
