feldpaum1975
- Jan 7, 2007
- 13
I own a 50hp 1989 Force outboard. It runs fine on top end but will not idle? It idles down to far and stalls out before I can put it in gear. I have taken off the carburetor and did what I knew to clean it, which was just spray it out with carb cleaner, took off the float and cleaned under that needle, and pulled the sleeve off from the center needle and cleaned out them ports? Was wondering if anyone nows anything else it could be?
