Sounds like a carb thing.
Before you start pulling things apart try running a good shot of Sea Foam through the gas tank, the stuff is awesome.
I get mine at Speedway gas stations but it is probly at autozone too or any marina, red and white can,I swear by the stuff.
If you are lucky you have a bit of gunk in your carb and this will clean it out,good place to start before you pull stuff apart.
dirty carb. what type load is in the boat?
are you running a long shaft on a short shaft boat?
