Re: Carburator with electric pump question
Actually Bond-O, He DID NOT charge to open it up, inspect, and do a mild cleaning.  He checked the float bowls and the jets were clear.  The filter inside the carb(Weber thing) was clean!  "There was no need to rebuild it", he said.  I don't know of a rebuilder that would pass up the opportunity to not make money.
The reason I reposted this is because I was curious about the pump issue, If I added it to the last post, it would have been overlooked.
So if I am understanding this, without the pump, I have no flow whatsoever?  Ok, that answers that question.  I do realize there will be cold start issues with a carb, that's ok with me also.  Since I have been trying to locate the proper tools to check the fuel pressure, I have been collecting the parts needed to replace possible failure points(Fuel/water filter, anti-siphon, new section of fuel hose and a transfer pump to empty the fuel tank out). Once this is empty, I will have to inspect the pickup tube and in-tank filter for clogs and debris.  Then I will reassemble and fill with fresh fuel.
Basically, I will then be left with a weak electric fuel pump as the last resort. Unless there is something else I am missing?
