1986 mercrusier 260 580hrs
I bought this boat this summer as a restoration w/t my son
when i looked at the boat there was water in the boat on the trailer up to the storage in front full looked at the engine was surprised how well the engine looked .
the owner tried to start the engine with starting fluid i was not there !
when i got the boat home there was water in the gas tank 20 gal 38 gal tank
a screw was missing in the regulator
engine had water in oil figured it seeped in through the pan gasket
i changed the oil ran the engine checked the compression 120 in all but #3 was @ 90psi .
checked the dip stick oil looked fine was happy went to change oil oil yesterday to take boat out for a run oil was a lil milky not as bad as the last time pulled all the plugs all looked ok pulled the hoses off the thermostat housing connected a garden hose to the with a spliter drained the oil and was looking for water draining from the oil pan and cylinders nothing! left it ove nite nothing !:
could this be residue from the dry sink ? what is the best way to flush it to make sure befror i break it down
Everyone has these moments.
