Nissan Pathfinder Stumbles
mscher
Hey,
Our 98' pathfinder (3.5 v6 - m/t) with 115K mi, has ran like a champ until recently.
Often, though not always, it will stumble during acceleration, but will smooth out when up to speed. Plugs and wires were replaced in the spring.
Could be bad gas (lot's of ethanol out there), but we don't always buy at the same place?
It has never been to a repair garage, so is there something they can test for that may determine a cause?
Anything else that I can look for? I'm not getting any code errors.
thanks
i386
Re: Nissan Pathfinder Stumbles
Fuel filter is the first thing that comes to mind.
ob
My 97' did the same thing at 65,000 miles.Turned out to be the throttle position sensor.I had no check engine light either.I recommend having it diagnosed by a competent dealer tech to narrow down which component is possible culprit.
dolluper
With no codes your back to basics>>>fuel,ignition,grounds or green connections also make sure your charging system is up and running right very important with computer controlled vehicles.Does your problem happen on a cold vehicle or after it has reached operating temperature?????
KM2
The ethanol has nothing to do with your problem, so start looking somewhere else.
mscher
Seems to happen warm or cold.
I'll try the fuel filter next.
dolluper
In that case try a fuel filter {cheap easy} maybe do a fuel pressure test after,also check your MAF {mass air flow sensor},simple test is with the engine running tap the sensor with the wooden end of a hammer, the vehicle will stumble if working right.might take a couple of taps. It;s located in your air duct work for breather,also make sure your air filter is not plugged
Windykid
I would check the fuel filter first. But a drop of 1-2psi can cause a chug, surge or stumble at various RPM. So do a fuel preasure test.;)
LubeDude
All the above things are good advice, but you mentioned changing the sparkplugs! Did you use the same ones that were there already, or did you use something different. Just for example, some engines just do not like the new platinum plugs.
mscher
I did install Bosch platinums, but they are the same as the second set. I think the originals were ND's.
Windykid
What have you done so far?
LubeDude
Meaning that you replaced the set that was in there with the exact thing that was in it before??
I had a 87 4 cyl Toyota 4X4 that loved them, (Bosch Platinums) But my 6 cyl 4 LTR 4X4 Ranger hated them.
orion25
The throttle body could be dirty. Get some cleaner and read the directions on the can. The TPS and MAF could be the problem as well. The way it sounds your problem is either fuel or air and the fuel was covered in the previous posts about the filter. Also, replace your PCV valve. They are cheap and can sometimes cause problems.
i386
whatever happened with this one?
MikDee
Banned
Keep it simple, First thing I'd check is the air filter, then the fuel filter, at 115k miles when were they changed last?
