ziggy
- Jun 30, 2004
- 7,473
evening peoples, i was thinking about putting my lower and my upper back together tonight. got it all greased up. anyways, got me a new concern. my drive shaft has a groove in it.....
i assume caused by this lower seal in the upper.....
question is, should i do something about it. i did hold 15psi prior to disassembly. 5'' of vacume, maybe 4, did rotoate while testing.
i guess my feeling is the drive shaft don't look good. i ain't got to much bread left after doing other stuff to the drive. think i should speedy sleeve it? put me a seal in the upper? the seal best i can tell, (feeling it) seems smooth enough, not tore, somewhat plieable???? looks like it wore a groove in my drive shaft to me though. any opinions one way or the other? other than R&R the drive shaft + replace the seal..... am i dreamin that i can get away with it as is since it passed a pressure, vac test?
