Re: Building Ideas Need help
fuzzy i been thinking of this for a while....and out side of sand bags on the base of the pedistal....
 i cant think of any way to do it.....
im assuming you dont want to drill holes in your floor because of rot potential??...is that correct?
if it is.....after the floor has been re in forced from below...to accept the pedistal.....just pre drill the holes...add 5200.then screw the pedistal into place using stainless screws.
out side of that....the only thing i can think of is to build a 2x4 frame around the pedistal base and then glass the frame to the floor....and personally i think it would look really weird. not to mention you would stub your toe on it all the time
good luck with it....keep us posted if you come up with somthing
cheers
oops
