Mr.Stuart
 - Jul 18, 2007
 - 701
I took the Starcraft out this weekend and ran over a log, it bent up the prop a little, not real bad, but it's a little chipped and dented, the prop that's on the boat now is a 13x19 3 blade and the boat seems to do ok with it, top RPM is about 5,000, and top speed is somewhere around 40 to 45 MPH.
I just replaced the throttle cable, and before I replaced it, I was getting close to 50 MPH at almost 5,500 RPM's so my RPM's have dropped a little but I'm thinking that is due to the new throttle cable, and with the high end around 5,000, I feel that's adequate at least for me, and the prop that's on it seemed to me to be a little worn, and I had considered replacing it anyway, but I'm not sure with what.
The boat is used for cruising, not really much water skiing or anything, just going out and putting around, doing some fishing and such.
So the question is, what prop do I want to run on it, 3 blades? 4 blades? I was doing some looking on eBay, and can't seem to find a 13x19 prop, so where do I go from here? what size and pitch do I want?
Stuart
Stuart
