Re: Fiberglass restoration & polish
Gentlemen......
Ok,here's what ya do..rent or buy a heavy duty variable speed sander/polisher,milwalkee/makita.
2) -local auto paint store -3M SUPERDUTY COMPOUND
3) -3M Hookit backer & pads
4) - 3M finesse it - polishing compound
5) -Collinite #845 Insulator wax
Wash down the boat using TSP (local hardware store) let dry.
Apply superduty, as you would wax,hand apply only
Use buffer to remove compound,gently,w/ just enough pressure to remove compound.
after that use Finesse it,same instructions as compound.
after making sure all compound & polish has been removed,wash again with soap,and let dry.
Apply Collinite changing rag sides frequently,let dry,remove by hand,repeat last. The job will last about a year,only use BOAT soap to wash.
Yea its hard work,but it lasts,and any product claiming easy/fast/like new....FORGET IT,The ONLY way to achive a great wax job is with hard work. Good Luck Amigo's
