john from md
- Apr 13, 2008
- 2,184
1985 Force 85hp
Can anyone tell me how to remove the check valve at the fuel OUT side of the fuel pump? I can drift out the one that sits on the fuel IN side and, of course, the center one removes with two screws.
My reason for removing them is that they all are sticking and won't free up by cleaning with chemicals. It appears that the amber colored plastic poppet has expanded (maybe from ethenol fuel?) and the spring does not have enough power to pop them back.
I was able to play with the removable valve and could see plainly that the plastic did grab on the "cage" legs. I was able to slightly bend the legs on the center valve a hair and this freed up the poppet.
I believe this is the cause of my intermittant running lean and shutting off. It seems logical as some times, I wasn't able to get the ball hard even after the carbs were rebuilt and diaphram was replaced.
I'm thinking that I can break the poppet section of the OUT valve, make a threaded 'J' hook and, using a plate across the pump body, screw a nut on the "j" shaft to pull the valve out. I have a arbor press for pressing in the new valves.
If anyone has any better Ideas, I would love to hear them.
Regards,
John
Regards,
John
