This is going to be a bit long.
I have a 1970 Stamas Boat with a 150 HP Mercury Black Max Engine.
The engine has been running fine for me, but the starting has been a real problem.
Last summer I'd been having issues with getting it started and had to move the throttle around while starting it to get the starter to "engage"
When it acts up you just turn the key and listen to absolutely nothing happen.
My engine shop and I thought this sounded like a neutral safety switch issue, and I had it replaced.
The boat did better the next time I was down there (though not perfect)... meaning that it was more consistently getting some action when starting rather than just the dead click.
But after that, it got even worse.
I called the shop back and said I wanted to get it checked out and see what the next step was towards making it work.. The starter seems fine, but something is keeping it from engaging.
They got back in there and cleaned and lubricated the starter, said it was gummed up with debris.... When I got down there this Thursday it was working like a DREAM! Almost 100% connection on the starter. By Saturday it was back to its old tricks again of not working.. by Sunday there were a few times when I wasn't even sure if I was going to get it going. Once it gets started, it runs just fine.
I talked to the shop again and they said the next move is to replace the entire control box.. a $300 part plus probably $200-300 in labor....
Before I do this:
1) does anyone have any other ideas?
2) will a new control box solve my problems?
3) will a new control box be compatible with a new engine if I purchased one?
Before I do this:
