Mark42
- Oct 8, 2003
- 9,334
Lately the water pressure upstairs has not been very good. It has gotten so low at times that if both showers are on at the same time, one will kick off the shower head and run water out the spiggot.
The house has a well and large pressure/holding tank. Both the tank and the well pump were replaced about 6 years ago, and are heavy duty for the house needs. There is also a cartrige type filter after the pressure tankl and before the water softener.
I let the water run and the well kicks on at 35 psi and off at 60 psi. which is how its been for years. I had replaced the cartrige filter about 2 months ago when I first noticed the pressure drop. When the filter starts to clog, pressure drops and that's how I know to replace it. Takes about 4-6 months to clog. Putting in a new cartridge didn't seem to make much difference.
This morning I put both showers on, and then opened the water softener bypass valve. That made a big difference. The water was coming out nice and strong in both showers. So I put the softener on recharge. This evening it didn't seem to make much difference. So I adjusted the water pressure to raise the cut in to 40psi, and still cut out at 60psi. Its a little better, but not great.
So I think the softener is the problem. Do they "go bad" and have the media bed clog up? It seems that passing water through the filter is cutting the pressure more than it used to. I recall that the softer said it will cut about 5 psi off the line. Must be much more than that now. The softener was put in around 1999 or 2000 and is a large capacity Sears unit.
Any suggestions or comments? Think I need to replace the softener?
