CliveWinston
- Mar 2, 2009
- 2
I have a 2002 Rinker w/6.2 MPI and Bravo 3. My problem is the engine will only start if you give it gas. You crank it and get it running (having to rev ) and then after a 20 seconds or so it will idle in neutral. THe motor runs fine, has new plugs but I have this starting problem. Doesn't matter if the engine is cold or hot. Sometimes it will start right back up if you try it just after you shut it down, but if it sits, even for 10 minutes, you have to use throttle to get it cranked, where I should just be able to bump the key with a MPI motor. Any help greatly appreciated
