Mercury 7.5 Spark Issues ?
Laddies
Banned
Re: Mercury 7.5 Spark Issues ?
The 7.5 use 3 or 4 different ign systems, start with a serial number if you need help.
Laddies
Banned
Here's the ign. test
shaun007
ok i took the coils off the motor and removed the rubber boots that protect
each coil
and one of the coils has a broken magnet
it is broke in 2 different places
so my question is ! where can i buy these coils at ?
i have searched the websites and no such luck
the coils are orange and the part numbers on each coil are below
# 339 5288 5 79
#339 5288 45 78
any help would be great !
Laddies
Banned
339-5288T2 Mercury, there is not a after market coil available
shaun007
ok i have new stator coils and ignition coils !
how do i change the coils on the stator ?
i dont want to break them when removing them
but it looks like a metal clip holds them on
Laddies
Banned
Pry the top retainer clip up on the inside of the lamination and tap the coil off.
shaun007
ok i got them off and put the new ones on !
and i also replaced my ignition coils and still no spark !
i also replaced the kill switch !
is there something im missing ?
do you have a diagram for the wiring so i know that everything is hooked up the correct way ?
thanks for your help !
cell
It might be easier if you had a manual....thats if you don't have one now.
shaun007
if i had a manual i would not be on here asking for help !
green4themoney
i believe your motor is a 1975 unless somebody changed the cowling cause i have a 110 and it looks EXACTLY the same and they changed their cowlings almost every year... i know that was their cowling in 79
ignition system is type IV. thunderbolt CD ignition pointless with a coil per cylinder
so your motor contains an ignition stator a trigger coil and a switch box
shaun007
the motor you see in that ebay listing is not mine !
and when i said it looked like the one in the pic i meant the pic that
showed the orange coils !
my motor is a 79 mercury 7.5
and yes mine contains an ignition stator a trigger coil and a switch box
