I have an 1976 75 HP Evinrude that I cleaned up and took out for the first time today. Out of the water the engine runs great. When throttled up runs around 7K RPM's. We get it out on the water and push the throttle forward and she stalls out so we took the cover off and noticed that the spring wasn't pushing the timing advance so we moved it by hand. She ran at full throttle at around 6-6.5K RPMs for about 15min. Then she cut down to 3.5K RPM's at full throttle. We checked the throttle linkage that is good, checked spark that is good.
So I have 2 questions is there a way to lube the timing advance to free it up so the spring can push it forward or is the spring bad?
And why did the engine drop to 3.5K RPM's at full throttle and still won't go to max RPM's at full throttle?
Timing advace only works if you advance it by hand in the water. But why does it run good without the timing advancing out of the water?
Any help would be great thanks.
