I have a 65 johnson meteor II, starts right up, idles fine, runs up to 1/3 to 1/2 throttle and then bogs down. I have changed the plugs, new fuel tank, lines and bulb and additional fuel filter in line before motor. I have run 1/2 of tank of fuel with a strong mix of Sea Foam through the motor (current tank im running is still sea foam mix). Have sprayed sea foam into carbs, and used alot of carb cleaner. Again, the boat fires right up will idle fine and run at about 1/3 speed. If I use the throttle and spray starting fluid continually into the carb I can get the motor to rev up and get the boat to about 40 mph. It seems like the motor is starving for fuel...
I'm at the river now and would love to get it running right today.
Also, I can't seem to find a carb kit for this model on line. A local suppler that has alot of parts for this motor could not find a part # for a kit but has individual parts listed for the carb.
