Force 125 fuel pump kit 1988
Car-guy
I have no top end power, checked everything except the stator and the fuel pump I have never rebuilt the pump so I order a rebuilt kit from iboat, it didnt come with replacement valves. I have taken the top cover off but the base is stuck to block, can I pry on it or should I take aputty knife and try to pound it in? Are the valves under that? someone told me one might be stuck or rusted?
john from md
Re: Force 125 fuel pump kit 1988
The pump cover comes off with six screws. Inside the cover are three check valves. They cost $5 apiece from www.mercruiserparts.com or maybe even iboats has them. Don't going prying around with a screwdriver.
John
jerbear56
Those covers definitely get stuck! What has always worked for me is to tap lightly on the corners of the cover with a plastic hammer.
Car-guy
Thanks Ill try a rubble hammer. Should i replace them even if they look good? I asked iboat and he didnt have a number for them, thanks Ill get some ordered anyway.
jerbear56
I doubt that a rubber hammer will do it. If you don't have a plastic tipped hammer, just hold a screwdriver by the shank and rap it with the plastic handle.
I'd replace the gaskets, even if they look good. Try this number for the gasket. F438760
Car-guy
I meant plastic, I ordered the kit 18-7806 and thought I would get everything I would need, Im going to order the valves and ill ask about the gasket you said anything else??? Dos the 18-7806 come with the cover to pump gasket? Can anyone tell me about a link to look at pic. of the whole pump? I ordered the manual. Thanks for everyones in put.
Car-guy
Thanks I have everything on order, The link was what I was looking for.
