This_lil_fishy
Master Chief Petty Officer
- Jul 23, 2008
- 841
Re: Solo Launching
I've been practicing this quite a bit. Something to note though is that the boat will pivot close to center. So as the stern swings in, the bow swings out. Thus is best to apply reverse once the bow is very close to the dock. I've not perfected this, but have been practicing the last few times I've been out. Fortunately where I do most of my boating, the docks are very easy to approach and moor to. When I rent a slip it's a completely different story, and I've failed quite a few times...relying on helpful bystanders. Some day I will get it right.
Ian
Cool JZ, hope you have fun doing it by yourself. I went out yesterday all by my lonesome and had a great day although it was very windy.
Here is another little trick I learned and after trying it out a few times I wonder how I missed something so simple and effective.
This applies to docking when your coming back in, as you know doing it solo can be a challenge especially if its windy or the current is strong (the river I was on yesterday has a 5mph current).
When you approach come in at 45 degrees to the dock slowly but under power, as you get close (1-2ft) shift into reverse and turn the motor so it points to the dock and use reverse power to pull the stern of the boat into the dock. This not only stops forward movement but pulls you in parallel inches from the dock.
I am still practicing this maneuver as I usually don't dock at the same place more than a couple times a year but let me tell you it works so slick you will look like a professional.
Heres a little tutorial in pictures so you get the idea, sure makes docking a breeze especially if your solo.
http://www.tropicalboating.com/powerboating/docking-an-outboard.html
Ian
