Re: Folding trailer thing
Red Green it....cut a hole in the door...sheesh....
You laugh, I have a buddy that thought about doing that, then he cut a hole in the back of the garage to let the motor stick out. He later built a lean too around the cutout. The great part is that he can open the back door on the lean to, slip in a barrel and run his motor in the garage and not make a mess.
He gained about 31" that way.
I have seen cutouts in garage doors, even one that was done to clear a welded on trailer hitch on a guys work truck full tools. A guy I used to work with had a garage with swinging doors with a flap over cut out holes to clear both the anchor pulpit and the trailer tongue. He eventually built a small overhang above each hole and built a box around the protruding boat parts. It looked like he had two big bird houses on his garage doors.
