Re: 8 Hp Evinrude Wot Problem
No numbers, sounds stolen, they are usually the first things to go to eliminate the chance of someone finding their motor (not saying it is) . Side of the transom clamp should be a plate with 2 little nuts holding it on or on the powerhead there is what looks like a frost plug with a number stamped into it. If you bought a kit for it how could you go into a dealership and tell them it is between a 1984 and 2001, there could be several kits between the years stated, my dealership would laugh at me and tell me to come back when I know what I have. An 84 for example has 3 different high speed jets that could work, a 1990 motor has an entirely different carb. I hope you saved the old parts. If I were you i'd clean the old main jet really well, get all the garbage out of it and reinstall it. Then you will know if you have the wrong jet and it will probably run better. Sounds like it's wrong, just a guess but it should do the trick, needle and float looks the same.
Cheers
