Hi im new to posting hear. This forum has helped alot in the past , but now i have to ask a question i cant find the answer. I have a 140 evinrude 1984 it has eletric choke were it shoots fuel in the carb not the old fashion butterfly kind but enyways about 3 months ago i blew the motor now im 7 hours in breakin and i can and feel confident enough to go to wide open throtle but when i did it didn't have the power it should have. I went through the process of elimination i presed the choke and it took of it idles ok it just runs lean on top end and i dont wont to blow the motor and it has good fuel presure. Carbs have just been rebuilt during motor rebuild. I have tried pumping the ball while at wot and it does nothing, the only thing that helps is pressing the choke then its like i hit nitrous the carbs have been rebuilt fuel is clean and filter is to. All new gas hoses to. So what could cause the loss of power and runing lean at wot but not at lower speeds its hard to choke trim and steer at the same time please help im desperate and at my ends with this motor everything else checks good besides wot running i cant figure it out thanks... ohh and im still running double oil 25:1 could this magnifie the effect. thanks.
