Re: 15hp Gamefisher by mercury
Alright, how long have you been using starting fluid to start the engine? Starting fluid has no oil, and will remove oil from everything it touches,(considering it flows over the crank, connecting rods, bearings, etc.)therefore when you start the engine it's probably doing a little bit of damage at a time until it lubes up. I would replace the plugs, check compression and so forth. If you have to spray it to start it use a spray bottle with with a gas oil mixture, that way you get some lube in there. Someone with alot more experience can probably help you more with the starting issue.
