Re: Trim/Tilt Question
Switch trim relays around(upper one to lower position & lower to upper position) Mine would trim up & wouldn't trim down. Would work right mosttimes however. The top Evinrude Johnson mechanic around here tested it & said the trim harness had a problem, but guess what??? I took a chance & replaced both relays & it works perfectly & faster than ever before. This was the first time i've ever known my mechanic to be wrong as he is top notch.Even when relays were switched around you could peck them with a screwdriver to get it to work right or when working right could get it to stop working. Very easy fix for $30.00 shipping & all from Iboats
