Looking for someone who has a lot of experience with or is an OMC Sea Drive expert and can provide some information and advice. I have some experience with Johnson and Mercury O/Bs but have been primarily a Yamaha O/B user/owner ? currently run a 115 Yamaha Salt Water Series engine on a 20? aluminum flats style jon boat.
I recently purchased a used 1988 18? Fiberglass Center Console boat with a 19?? OMC 1.6L Sea Drive. I like the concept of the fully enclosed transom similar to a stern drive setup. However, the engine needs considerable work.
The gear case has been trashed. The previous owner took it apart to fix it but lost parts including the gear case housing, most gears and the drive shaft. The engine turns over by hand ? the starter is frozen up from corrosion/rust. The wiring around the power head is marginal and needs to be replaced. The status of electrical and electronic components is unknown. The paint on the engine is faded and in some places worn away.
Where do I find the engine ID # or serial number so I can identify the year and model? I have looked everywhere for an ID plate but can?t find one. Is the ID # or serial # inscribed anywhere else on the engine?
I have heard rumors that the Sea Drives were not very reliable engines. Is this true? What were their major problems?
I believe this engine is somewhere between an ?84 to an ?88. It doesn?t seem like it makes much sense to spend a large amount of money (approx $5000) to repair an engine with old technology. Your comments?
What is the practicality of installing a late ?90s or early ?00 Johnson, Evinrude or Yamaha 115 ? 150 hp engine on the Sea Drive Tilt/Trim mount instead of having to install a Gil or Armstrong bracket?
Would I be able to operate the Sea Drive Tilt/Trim hydraulics with an independent switch and power? Or, does the Sea Drive T/T require interfacing with electrical/electronic units incorporated in/on the Sea Drive engine?
Any and all comments are appreciated.
Hank PTC, GA
Hank PTC, GA
