Hi,
I have a 2008 Volvo 3.0 GLM / SX drive which has a drive noise when the steering is turned to port, and the engine revs are at 2000. The noise only occurs when the drive is in neutral, and is very similar to gimbal bearing noise.
There is also a gear whine noise at exactly the same revs as the knocking noise when under way so was wondering whether the two noises are related.
The engine /drive is still under an extended waranty, and so far the dealer has checked the alignment, changed the gimbal bearing, u-joints, and the input bearing in the top of the drive housing.
Has anyone on the forum experienced this problem with the new style SX drive or have a solution for this problem.
I have been told by other engineers that it cold be a problem with the power steering ram, but the dealer does not believe there is a problem with the steering.
