To start with, motor sat up for a year.
Changed : impeller, spark plugs, lower unit fluid, TNT fluid, New fuel Tank, New Fuel lines - from tank to fuel pump, and from fuel pump to each carburetor. Carburetors, and fuel pump seemed to be clean, though cleaned each, and installed New kits to each, just to know what I had. to be on the safe side.
Very good spark to each plug, plug gaps, and carburetor linkage are right on the dot.
Checked to be sure Spark Advance plate moves freely with no sticking.
At first put on the muffs, motor fired up very first crank, idles perfectly.
Shift into forward or Reverse barely reving the engine, it went to speed up, though did not get to full speed. I guess the best way to explain what it sputters like, is as if it had a Rev. Limiter like some automobiles have. as in keep in park, and floor it only revs. up and down, without a steady acceleration.
Tried it out on the water, thinking maybe this motor does this only when running on muffs, though same-thing. (barely 5 MPH) Wide Open.
Even Double Checked that the vent on the fuel tank was opened. and just to be sure even though tank is New, thought vent perhaps may not have vented as it should so, also removed the fuel cap, while running.
Checked to be sure the choke solenoid, was positioned right. (parallel with the solenoid, as pointing away from it only chokes and kills the engine)
So I went ahead checked and did just about everything, as stated above.
Same scenario. Fires up very first crank,Idles perfect, Stills Revs. back n forth with throttle wide open, on Muffs, and on the water.
I've searched this forum over and over for about a week, days and nights at times, also Read the FAQ, the Secrets and all. lol
I've found some posts with almost similar problems, though that was another problems, lots of ideas on what to check. As I've already done, before finding this forum. Though I noted that, it seems most people Never post the solution to what they have done to fix the problem.
So I'm in hopes that whom ever may have had this problem or Similar problem, wouldn't mind sharing what they have done to Solve their similar problem.
