Re: 1988 Gamefisher 7.5 hp - splits unburned fuel
Two strokes that are run in a barrel make a mess. It is amazing how much unburned oil there is in a poorly tuned motor. Even well tuned at idle will make a mess. At 3/4 throttle they run much cleaner, but NEVER run above 15% throttle in a barrel for any length of time more than a few seconds, as the whole cooling system is not designed for it. Use the barrel mostly just to see if it runs, then put it on a boat and in a lake.
I would do a pressure test on the lower unit prior to putting it in the water to make sure you aren't leaking there. Pull the plugs, drain it then hook up a pressure tester, pump it up to about 12 lbs and it should stay there for more than 15-20 minutes. Then do the same test with about 6 lbs of vaccuum.
Good luck,
