the trailering bracket
Status
Not open for further replies.
trobador
I will like to know how to use the trailering bracket which will fit most 270 thru 290 Volvo outdrives from early 70's years thru late 80's.Think ill be better than using a rope
Thanks
Trobador
cr2k
Re: the trailering bracket
Those are WAY easier to use then the volvo wierd spring/'snap in ones.
PiratePast40
Yes - I totally agree, that bracket is very easy to use and works well. I put a piece of garden hose on mine to keep it from scratching the paint on the outdrive. Add a short bungee cord to hold the bracket tight to the leg and it does a great job.
smarrott
this is going to be a really dumb question, but here goes. do you remove when boating or just let it fall out of the way?
GA_Boater
This thread is over 7 years old. Please read the Help Tip on top of the page and start a new thread.
Closed.
But yes, you do remove the trailering bracket before using the boat.
Status
