Boat: 1996 Skeeter , with 1996 Mariner 115hp.
Recently serviced with lower unit gear lube replaced.
Problem: Took boat out on lake, at approx 35mph, beeping alarm came on, and will not quit. Alarm comes from where throttle box is, and light above RPM gauge blinks in concert with beeping alarm. Beep, pause, Beep,pause Beep and so forth.
I looked at oil level, it was low, but not too low. I added oil to reservoir, and topped it off. Beeping continues, even when you just stick key into ignition and turn to right.
Any ideas, temp?, short in wire/circuit? Any help appreciated. Thanks.
