Its in a 92 sunbird. I had a exhast leak where water was getting into the head. I have preplaced all gaskets at this time and I don't have a change in power. What I mean is the boat will not go no more than 10mph. It will not plain out. The oil pressure if the gauge works right is right at 10 psi while at idle and after about 5 mins of idle it will drop to 0 on the gauge. When the motor is at 2000 rpm it will have a little over 20 psi. I know it may need some timing and some carb work but what is causing my low oil pressure. Barrings getting bad time, time for rebuild, or sell boat?
