countvlad
- Jun 29, 2009
- 439
water pump and thermostats were changed a week ago... i used a infrared temperature meter to check the heads temperature and port side of the motor was 10 degrees lower then the starbord side. Took to motor out and it didnt over heat but i wasnt sure if thats normal or there might be an obstruction, problem?
thank you
thank you
