Re: remodeling kingscraft house boat
I plan on completly redoing it. The bottom is good. I am taking out all the interior walls except one, and I may take it before im done gutting it. I am going to replace the fresh water tank and pump. Replumb the entire boat. Re wire the 120 volt and 12 volt systems. There are a few leaks around the windows that once i get the walls removed I am going to recalk and seal. It has what appears to be a fairly new heat/ac unit in it. The sea pump for it is bad, so i will replace it. I am going to insulate as much of the walls and underneath areas as possible. I plan on using styrofoam sheets of insulation. Has any one you know used any of the spray foam type insulation in cans in the hard to reach areas? I was wondering if it has any chemical reaction with the alumium? I am going to figure out what tanks are for what on the boat, get all the old fuel pumped out. Im going to replace all the hoses ans seals on the engines. Also going to rebuild the sea pumps for them before i even attempt to start the engines. The boat has been floating for over 2 years and has not been started. I allow if I get them running before fall so be it, if not, i will wait till next spring. Proirty one, stop the few leaks, gut the interior and clean it up.
