Catfishmonkey
- Jun 6, 2010
- 97
Just picked up a 1973 15 foot Starcraft Holiday. Filled her up with water, and all the rivets, and seams seemed solid...no leaks. Oddly I had one leak, a hole in the bottom of the hull which was a bit smaller than a ball-point pen tip right in the aluminum. When I went to West Marine, they told me just to put some marine silicone on it, but I am thinking to Gluvit the inside of the hull completely, just to insure no new holes spring up after I install the floor. Should I do this in this situation, and if so, should I put the silicone on first/after the Gluvit/not at all? West Marine guys apparently did not hear about people using Gluvit on aluminum...strange. Anyhow, any advice would be much appreciated. Also planning to put some sort of epoxy paint inside and out.
When removing the floor I found a lot of disgusting chewed up white foam (like confetti)...thinking of replacing it with closed cell yellow polyethalene foam, for extra floation, and also to minimize the space any future water can get to...really in the hope of making the deck and sub-floor air (and water) tight. I also plan to put silicone around the outline of the deck, essentially making it so the only place water (when hosing it down, or getting hosed down in the chop) will go would be the bilge (using fiberglass boat principles I guess). Are there any reasons this would be a bad idea? Thanks
