Vic.S
- May 4, 2004
- 4,720
Re: charging system
Before fitting the new rectifier check the stator coil with your multimeter set to its lowest ohms range. You should get a fairly low resistance but I forget what.
If you get no reading it indicates that the stator coil is open circuited.
