charging system
Vic.S
Re: charging system
Before fitting the new rectifier check the stator coil with your multimeter set to its lowest ohms range. You should get a fairly low resistance but I forget what.
If you get no reading it indicates that the stator coil is open circuited.
Andy in NY
Re: charging system
where are the wires to check for that?
Vic.S
Re: charging system
They are the yellow and yellow/gray wires that were connected to the same colour wires on the rectifier.
Andy in NY
Re: charging system
okay i tested those wires on the lowest ohm setting and got a slight reading and if i spun the flywheel a little they jumped.
i got the new rectifier installed...
still no tach. but the new rectifier shows its good according to joe reeves testing procedure.
now heres the wierd part: my multimeter jumps like crazy when the motor is running... heres a video of it.
now heres the other thing: i can no longer shut it off with the key. i have to choke it out.
Vic.S
Re: charging system
If that is with the voltmeter connected to the battery it has me stumped.
Bad connection somewhere perhaps ?? something shorting ??
Tach not reading is suspicious too, not to mention being unable to stop it with the key.
Andy in NY
Re: charging system
well i think i figured out what is up with the key... i think my switch is going bad.. if i jiggle the key in the off position it will shut off.
daselbee
Re: charging system
Put the meter on the next highest range, whatever that is for your meter. Retry.
daselbee
Re: charging system
You have equipment problems. Test other things...your car, house voltages at the outlet, etc. to see if the meter reads those circuits properly. It absolutley should not jump around when engine is running. It this an expensive meter, or is it a Harbor freight $5.99 special?
Andy in NY
Re: charging system
i got it at wal mart, i think it was around 18 bucks.
daselbee
Re: charging system
seems to be meter problem. set on DC Volts, you should not get that "autoranging" bouncing around.
I do not think the engine has anything to do with the meter's behavior.
Re: charging system
Mine is doing the same thing. Just got it from WalMart for 17-18 bucks. Mine is a yellow ETek. I'll be replacing it with the $25 red one.
Andy in NY
Re: charging system
sounds like a plan, ill be returning it later today.
and thanks to everyone for the help... took her out saturday and didnt have any problems... well except for the not shutting off thing, but thats a different issue. looks like a new switch is what i need...
