Re: 1970 starcraft 25foot cabin cruiser help
If you have power running to the coil, your problem lies within either the coil, distributor, points, cap, wires, or plugs. What we know is good:
-coil
-spark plugs
-wires
-cap & rotor
Now, the only other thing left that needs to be checked is the points setup. Did you check them? Poorly set points will result in a no-start condition.
edit: Also, how is the grounding of the block? I recall one time I had a hard time starting my truck when the battery grounds became corroded.
