makeshifty
- Jun 28, 2010
- 11
My 1977 Johnson 115 v4 cold starts great, and runs very well However.....
After It runs for a while, usually 45 minutes or multiple starts for short trips, I cant get it to start again, unless I remove a spark plug. I first noticed this because I was testing each plug one at a time for spark, when I go to the third plug, it fired up by accident. Every time I've had this problem, if I remove the same plug, it starts right up. If I put the plug back in, it kills the engine. It almost seems like the spark plug is smothering the engine. If I wait for a long time, usually overnight, I can cold start it great with all plugs in. I don't think it has anything to do with flooded carbs as I've experimented extensively with my priming and choking habits on a hot start. My most recent theory, for however little it is worth, is that maybe the exhaust gets so clogged that it chokes the engine.
Any thoughts would be greatly appreciated. As it stands now, I have to assume that I'm staying overnight every time I pull my boat out. This greatly reduces my fun time.
Thanks
Thanks
