sublauxation
- Oct 13, 2008
- 1,317
Just dropped the boat in the water after rebuilding the transom and had water leaking through the bottom 2 motor mount bolts on an aluminum boat. Can I use 5200 to seal them or will they be to hard to remove this fall. Also, as a side, I had 2 small bolt holes I forgot to fill on the transom. They also leaked, I reached under the water with a finger full of 5200, dabbed some on each hole, stopped the leak immediately.
