NelsonQ
 - Aug 5, 2008
 - 1,413
Ok...let me first say I'm posting this for a friend and I know NOTHING about I/O.
He has a 4.3L Mercruiser (carbed) with Alpha I outdrive.
He purchased it with a 30 day warranty from a private seller. During that period, he sent it to a marina for an inspection and it all checked out great.
When my friend picked it up, they were having problems with the tilt/trim which they resolved but.....
Yesterday we dropped it in the lake. Runs like a champ, temp is normal with the outdrive trimmed all the way down. As soon as you trim it up 1/4 to 1/2 ways, the temp runs hot in about 10 secs and off goes the heat sensor alarm.
Trim it back down, put it in gear, and within seconds, the temp is normal again.
My though is something is restricted when trimming up (intake appears fine so I assume its on the return.) I know this is probably simple for you I/O guys.
IF you have any thoughts, I'm heading back tomorrow to the lake. Any suggestions appreciated.
Also, it will be going back to the marina but they're closed until Tues. Other interesting part as well is now when we turn the engine off, it stumbles for 3-5 seconds (I assume a timing issue, but the marina can have that problem)
